Ga door naar hoofdinhoud
Kyocera Hydro Life Rear-Facing Camera Replacement
Wat je nodig hebt
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: stap 1, afbeelding 1 van 1
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 2, afbeelding 1 van 3 Kyocera Hydro Life Rear-Facing Camera Replacement: stap 2, afbeelding 2 van 3 Kyocera Hydro Life Rear-Facing Camera Replacement: stap 2, afbeelding 3 van 3
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 3, afbeelding 1 van 2 Kyocera Hydro Life Rear-Facing Camera Replacement: stap 3, afbeelding 2 van 2
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 4, afbeelding 1 van 1
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 5, afbeelding 1 van 2 Kyocera Hydro Life Rear-Facing Camera Replacement: stap 5, afbeelding 2 van 2
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 6, afbeelding 1 van 1
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 7, afbeelding 1 van 2 Kyocera Hydro Life Rear-Facing Camera Replacement: stap 7, afbeelding 2 van 2
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 8, afbeelding 1 van 1
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: stap 9, afbeelding 1 van 1
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
Conclusie
Morgan Marshall
277 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 194
