Ga door naar hoofdinhoud
Kyocera Hydro Life Charging Port Replacement
Wat je nodig hebt
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: stap 1, afbeelding 2 van 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: stap 2, afbeelding 1 van 3 Kyocera Hydro Life Charging Port Replacement: stap 2, afbeelding 2 van 3 Kyocera Hydro Life Charging Port Replacement: stap 2, afbeelding 3 van 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: stap 3, afbeelding 1 van 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: stap 4, afbeelding 1 van 3 Kyocera Hydro Life Charging Port Replacement: stap 4, afbeelding 2 van 3 Kyocera Hydro Life Charging Port Replacement: stap 4, afbeelding 3 van 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: stap 5, afbeelding 1 van 3 Kyocera Hydro Life Charging Port Replacement: stap 5, afbeelding 2 van 3 Kyocera Hydro Life Charging Port Replacement: stap 5, afbeelding 3 van 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: stap 6, afbeelding 1 van 2 Kyocera Hydro Life Charging Port Replacement: stap 6, afbeelding 2 van 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: stap 7, afbeelding 1 van 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: stap 9, afbeelding 1 van 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: stap 10, afbeelding 1 van 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Conclusie
Rebecca Lamb
327 Reputatie
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 982
