Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In order to reach the motherboard of the mobile phone, the back assembly needs to be removed.
Wat je nodig hebt
Locate the small notch on the bottom right side of the phone.
To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
The SIM card slot can be seen in the middle left of the photograph.
The SD card slot can be opened and closed, as depicted by the tool.
The SD card itself slides into and out of the metal cover.
Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
Pry the back assembly away from the body on all four sides of the phone.
Start prying at the top and work around.
Remove the buttons for the volume and power-this will allow for easier disassembly.
