Ga door naar hoofdinhoud
Kyocera Event MicroSD Card Replacement
  1. Kyocera Event MicroSD Card Replacement, Battery: stap 1, afbeelding 1 van 3 Kyocera Event MicroSD Card Replacement, Battery: stap 1, afbeelding 2 van 3 Kyocera Event MicroSD Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event MicroSD Card Replacement: stap 2, afbeelding 1 van 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
  3. Kyocera Event MicroSD Card Replacement, Locate the SIM card: stap 3, afbeelding 1 van 1
    • The SIM card slot can be seen in the middle left of the photograph.
  4. Kyocera Event MicroSD Card Replacement, Open slot and remove card: stap 4, afbeelding 1 van 2 Kyocera Event MicroSD Card Replacement, Open slot and remove card: stap 4, afbeelding 2 van 2
    • The SD card slot can be opened and closed, as depicted by the tool.
    • The SD card itself slides into and out of the metal cover.
    • The gold tipped tines are what read the SD card along its bottom.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
graysonmensah
22 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-4, Michaels Spring 2015 Lid van Ohio State, Team 1-4, Michaels Spring 2015
OSU-MICHAELS-S15S1G4
3 Leden
4 handleidingen geschreven
3 opmerkingen
That's the micro SD slot. That's not for a SIM card.
Carl Jr - Antwoord
What if there's no metal cover?
Michael ansley - Antwoord
That's for the sd card not the sim card
gasparesparza9 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 7
Altijd: 3,067
