Ga door naar hoofdinhoud
Kyocera Event Battery Replacement
Wat je nodig hebt
  1. Kyocera Event Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Kyocera Event Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Kyocera Event Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the small notch on the bottom right side of the phone.
    • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
    • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
  2. Kyocera Event Battery Replacement: stap 2, afbeelding 1 van 1
    • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
    • The plastic prying tool can be used to help remove the battery.
Conclusie
Jen Michaels
22 Reputatie
1 Handleiding geschreven
Ohio State, Team 1-1, Michaels Fall 2013 Lid van Ohio State, Team 1-1, Michaels Fall 2013
OSU-MICHAELS-F13S1G1
1 Lid
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 26
Altijd: 4,325
