Ga door naar hoofdinhoud
Kurio Xtreme Speaker Replacement
Wat je nodig hebt
  1. Kurio Xtreme Speaker Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the rubber case by beginning to peel from one of the top corners and continue peeling until the cover is completely removed.
  2. Kurio Xtreme Speaker Replacement: stap 2, afbeelding 1 van 2 Kurio Xtreme Speaker Replacement: stap 2, afbeelding 2 van 2
    • Unscrew the four 4 mm black screws using a Phillips #000 screw driver.
    • There are two screws on each side of the device (four total).
  3. Kurio Xtreme Speaker Replacement: stap 3, afbeelding 1 van 3 Kurio Xtreme Speaker Replacement: stap 3, afbeelding 2 van 3 Kurio Xtreme Speaker Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool in between the edges of the blue front casing and black back casing.
    • Slide the plastic opening tool around the perimeter of the device. This may require that you repeatedly run the opening tool up and down the edges of the device.
    • Be sure not to break any of the plastic clamps along the edges of the device when removing the back cover.
    • Carefully lift the back panel off of the rest of the device.
  4. Kurio Xtreme Speaker Replacement, Speaker: stap 4, afbeelding 1 van 2 Kurio Xtreme Speaker Replacement, Speaker: stap 4, afbeelding 2 van 2
    • Disconnect the 2 sets of black and red wires (4 wires total) from the motherboard by soldering the ends connected to the motherboard.
    • The soldering iron gets very hot and may injure you if exposed to your skin.
  5. Kurio Xtreme Speaker Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the speakers out of the plastic molds by lifting up the black and red wires.
Conclusie
Mallory Myers
1.190 Reputatie
7 handleidingen geschreven
Baylor, Team 6-10, Williams Fall 2015 Lid van Baylor, Team 6-10, Williams Fall 2015
BU-WILLIAMS-F15S6G10
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 210
