Ga door naar hoofdinhoud
Kurio Touch 4S Speaker Replacement
Wat je nodig hebt
  1. Kurio Touch 4S Speaker  Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: stap 2, afbeelding 1 van 3 Kurio Touch 4S Speaker  Replacement: stap 2, afbeelding 2 van 3 Kurio Touch 4S Speaker  Replacement: stap 2, afbeelding 3 van 3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: stap 3, afbeelding 1 van 2 Kurio Touch 4S Speaker  Replacement: stap 3, afbeelding 2 van 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: stap 4, afbeelding 1 van 1
  5. Kurio Touch 4S Speaker  Replacement: stap 5, afbeelding 1 van 1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: stap 6, afbeelding 1 van 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: stap 7, afbeelding 1 van 1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: stap 8, afbeelding 1 van 1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: stap 9, afbeelding 1 van 1
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Moin Khan
234 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-5, Brown Winter 2015 Lid van USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 160
