Ga door naar hoofdinhoud
Kurio Touch 4S Screen Replacement
Wat je nodig hebt
  1. Kurio Touch 4S Screen Replacement, Screen: stap 1, afbeelding 1 van 1
    • Make sure to open the back cover easily using the plastic opening tool
  2. Kurio Touch 4S Screen Replacement: stap 2, afbeelding 1 van 3 Kurio Touch 4S Screen Replacement: stap 2, afbeelding 2 van 3 Kurio Touch 4S Screen Replacement: stap 2, afbeelding 3 van 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Screen Replacement: stap 3, afbeelding 1 van 2 Kurio Touch 4S Screen Replacement: stap 3, afbeelding 2 van 2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  4. Kurio Touch 4S Screen Replacement: stap 4, afbeelding 1 van 1
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you get them out of order.
  5. Kurio Touch 4S Screen Replacement: stap 5, afbeelding 1 van 1
    • Remove the plastic cover that is covering the camera area.
  6. Kurio Touch 4S Screen Replacement: stap 6, afbeelding 1 van 1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Screen Replacement: stap 7, afbeelding 1 van 1
    • Use Phillips # 1 screw to open the 4 screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Screen Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Screen Replacement: stap 9, afbeelding 1 van 1
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Screen Replacement: stap 10, afbeelding 1 van 2 Kurio Touch 4S Screen Replacement: stap 10, afbeelding 2 van 2
    • Detach all the wire that are connected to the motherboard.
    • Also remove the camera module and other components that are attached to the motherboard.
    • For more information on soldering Click here
  11. Kurio Touch 4S Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Screen Replacement: stap 12, afbeelding 1 van 1
    • Use the Plastic opener to remove the screen.
    • Do not apply too much pressure as the front cover could be damaged.
  13. Kurio Touch 4S Screen Replacement: stap 13, afbeelding 1 van 1
    • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  14. Kurio Touch 4S Screen Replacement: stap 14, afbeelding 1 van 1
    • Use tweezers to remove the screen from your Kurio Toich 4S.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Ali
184 Reputatie
1 Handleiding geschreven
USF Tampa, Team 6-5, Brown Winter 2015 Lid van USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,369
