Inleiding
This guide will show you how to replace your front & back camera of your Kurio Touch 4S
  1. Make sure to open the back cover easily using the plastic opening tool.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Remove back cover by prying away from the Kurio. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides. The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  6. Remove the battery because it blocks the plastic shield that covers the camera.
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  7. Remove the plastic cover that is covering the camera area using tweezers.
    • Remove the plastic cover that is covering the camera area using tweezers.
  8. Separate the two halves of your Kurio Touch 4S. Gently use a brush to remove any dirt or finger prints around the area.
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  9. Remove the copper wires by using the Tweezers to replace your new camera. Remove the copper wires by using the Tweezers to replace your new camera.
    • Remove the copper wires by using the Tweezers to replace your new camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Khalid AlTamimi
251 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-5, Brown Winter 2015 Lid van USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Leden
5 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 1
Altijd: 208
