Ga door naar hoofdinhoud
Kurio Touch 4S Front & Rear Facing Cameras Replacement
Wat je nodig hebt
  1. Kurio Touch 4S Front & Rear Facing Cameras Replacement, Front & Rear Facing Cameras: stap 1, afbeelding 1 van 1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 2, afbeelding 1 van 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 2, afbeelding 2 van 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 2, afbeelding 3 van 3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 3, afbeelding 1 van 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 3, afbeelding 2 van 3 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 3, afbeelding 3 van 3
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the philips#1 Screwdriver.
  4. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 4, afbeelding 1 van 1
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you miss them up.
  5. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery because it blocks the plastic shield that covers the camera.
    • Do not remove the wires that are attached to the battery and the motherboard.
  6. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 6, afbeelding 1 van 1
    • Remove the plastic cover that is covering the camera area using tweezers.
  7. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 7, afbeelding 1 van 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 7, afbeelding 2 van 2
    • Separate the two halves of your Kurio Touch 4S.
    • Gently use a brush to remove any dirt or finger prints around the area.
    • Use the Tweezers to detach the front and back camera from its place.
  8. Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 8, afbeelding 1 van 2 Kurio Touch 4S Front & Rear Facing Cameras Replacement: stap 8, afbeelding 2 van 2
    • Remove the copper wires by using the Tweezers to replace your new camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Khalid AlTamimi
275 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-5, Brown Winter 2015 Lid van USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 242
