Inleiding
This guide will show you how to replace your Kurio's battery.
  1. Make sure to open the back cover easily using the plastic opening tool.
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Remove back cover by prying away from the device. The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides. Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top, then try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver. To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver.
  5. After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
    • After you remove your four screws use your plastic opening tool to help you open the plastic cover of your device.
  6. Use the plastic opening tool to remove the battery from its place.
    • Use the plastic opening tool to remove the battery from its place.
    • The battery is glued into the device. So try removing it gently.
  7. Remove the two wires using soldering tool to detach your bad battery from the device .
    • Remove the two wires using soldering tool to detach your bad battery from the device .
    • Gently remove the wires one by one. Do not damage the head that is glued into the motherboard.
    • For more information on how to solder and desolder the wire Click here
Conclusie
Khalid AlTamimi
251 Reputatie
2 handleidingen geschreven
USF Tampa, Team 6-5, Brown Winter 2015 Lid van USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 Leden
10 handleidingen geschreven
Één commentaar
do you know where to buy a replacement battery ?
Phil Bowring - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 1
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 4
Altijd: 1,268
