Inleiding
This is an easier part to replace than many others on the Kurio 7. Most require soldering, but this one does not. However, you must exercise extreme care when taking the device apart so that none of the soldered connections are broken. In the event that they are broken, look to our other guides for repair tips.
Wat je nodig hebt
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Carefully set the battery aside.
This is tricky, and an extra pair of hands may help. Use the opening tool to pry the screen out from underneath the tabs holding it in place.
Once you have created some space between the screen and the cover, slide the opening tool under the screen.
Slide the opening tool around the outside of the screen, releasing the tabs as you go along.
Replace with new screen. Reassemble by completing the steps in reverse order.
14 andere personen hebben deze handleiding voltooid.
4 opmerkingen
Hey Eric.
Nice guide with Pro-tricks.
Maybe you can tell me, where to buy new LCD-screen for Kurio 7S C13000
I've been Googled all places, but haven't found anything.
Hope to hear from you.
Please send a mail at us.oerbaek@gmail.com
Thanks a lot.
Mr. Skott, Denmark
Hi can you fix the kurio watch? My son got one for Christmas and broke it already. He has cracked the screen top half won't work but the bottom still works you can see everything still on the screen.
If anyone has any help could you email me please nchambers1@hotmail.co.uk
Hello, I’m Jeremy. I have a Kurio 7s that screen has cracked. It used to wor, but progressively got worse. I used to not be able to get past the home screen. Now, it doesnt turn on and even if charged it always says low battery. If you can fix this, my email is germookd@gmail.com
