Ga door naar hoofdinhoud
Kurio 7 Battery Replacement
Wat je nodig hebt
  1. Kurio 7 Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Kurio 7 Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Kurio 7 Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Begin by removing the rubber cover from the Kurio 7.
  2. Kurio 7 Battery Replacement: stap 2, afbeelding 1 van 2 Kurio 7 Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the four 30 mm Phillips #00 screws from the outer case.
  3. Kurio 7 Battery Replacement: stap 3, afbeelding 1 van 2 Kurio 7 Battery Replacement: stap 3, afbeelding 2 van 2
    • Insert the plastic opening tool in the gap between the front cover and the back cover of the device.
    • Slide the plastic opening tool around the edge of the device. Gently pry apart the tabs that hold the front cover and the back cover together.
    • Be careful not to break off the tabs that hold the front cover and the back cover together.
  4. Kurio 7 Battery Replacement: stap 4, afbeelding 1 van 2 Kurio 7 Battery Replacement: stap 4, afbeelding 2 van 2
    • Once all of the tabs are removed, the back cover should come off easily.
    • Gently remove the back cover. There are wires inside that may get caught on the cover while removing it. These wires are soldered to their components and are difficult to reattach.
  5. Kurio 7 Battery Replacement, Battery: stap 5, afbeelding 1 van 1
    • Use a credit card, or other thin object, to separate the battery from the screen.
    • Be sure to work the card slowly and carefully in order to not damage, break, or deform the battery.
  6. Kurio 7 Battery Replacement: stap 6, afbeelding 1 van 1
    • Desolder, or separate using the desoldering braid, the marked areas on the motherboard to remove the old battery.
    • Refer to our soldering guide on how to solder and desolder.
Conclusie
Solder in the new battery. To reassemble your device, follow these instructions in reverse order.
Alex Powaser
331 Reputatie
2 handleidingen geschreven
Cal Poly, Team 12-36, Maness Spring 2014 Lid van Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Leden
14 handleidingen geschreven
Één opmerking
Can the charging port be replaced in the kurio 7s tablet
Pamela Haughton - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 13
Altijd: 16,812
