Ga door naar hoofdinhoud
Krups F203 Coffee Grinder Plug/Cord Replacement
Wat je nodig hebt
  1. Krups F203 Coffee Grinder Plug/Cord Replacement, Base Plate: stap 1, afbeelding 1 van 1
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Krups F203 Coffee Grinder Plug/Cord Replacement: stap 2, afbeelding 1 van 3 Krups F203 Coffee Grinder Plug/Cord Replacement: stap 2, afbeelding 2 van 3 Krups F203 Coffee Grinder Plug/Cord Replacement: stap 2, afbeelding 3 van 3
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Krups F203 Coffee Grinder Plug/Cord Replacement: stap 3, afbeelding 1 van 2 Krups F203 Coffee Grinder Plug/Cord Replacement: stap 3, afbeelding 2 van 2
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: stap 4, afbeelding 1 van 2 Krups F203 Coffee Grinder Plug/Cord Replacement, Detach Trigger Button from Base Plate: stap 4, afbeelding 2 van 2
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  5. Krups F203 Coffee Grinder Plug/Cord Replacement, Remove the wire from two contact points: stap 5, afbeelding 1 van 1
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Ian Hancock
414 Reputatie
3 handleidingen geschreven
Baylor, Team 4-2, Williams Fall 2014 Lid van Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 15
Altijd: 2,904
