Inleiding
If the motor in your Krups F203 coffee grinder is faulty, you will need to replace it. This guide will explain how to access the motor in order to replace it.
Onderdelen
Geen onderdelen nodig.
  1. In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  4. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  5. The trigger button is held in with light tension clips. Gently pry them back to release.
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  6. Remove the white trigger. Remove the white trigger.
    • Remove the white trigger.
  7. Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
    • Be sure to reference the how to solder video posted to the device page
  8. Desolder remaining contact point from the plug cord
    • Desolder remaining contact point from the plug cord
  9. Using a Phillips screwdriver, remove the two screws  holding the motor in place. Using a Phillips screwdriver, remove the two screws  holding the motor in place.
    • Using a Phillips screwdriver, remove the two screws holding the motor in place.
  10. Remove the motor from the shell.
    • Remove the motor from the shell.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Ian Hancock
381 Reputatie
3 handleidingen geschreven
Baylor, Team 4-2, Williams Fall 2014 Lid van Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 Leden
4 handleidingen geschreven
thank you so much
Nikolai Podrez - Antwoord
Doesn’t seem to apply to the Type 203. It looks different.
rpoland - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 10
Afgelopen 7 Dagen: 47
Afgelopen 30 Dagen: 275
Altijd: 10,445
