Ga door naar hoofdinhoud
Krups 963 Power Switch Replacement
Wat je nodig hebt
  1. Krups 963 Power Switch Replacement, Removing Bottom Screws: stap 1, afbeelding 1 van 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Krups 963 Power Switch Replacement: stap 2, afbeelding 1 van 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Krups 963 Power Switch Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Krups 963 Power Switch Replacement, Power Switch: stap 4, afbeelding 1 van 1
    • Use your hands or a pair of needle nose pliers to remove the wire attached to the switch.
  5. Krups 963 Power Switch Replacement: stap 5, afbeelding 1 van 1
    • Grip either in the inside or outside of the switch with the needle nose pliers or your hand, and pull to remove the switch.
Conclusie
Wyatt Hall
842 Reputatie
7 handleidingen geschreven
Cal Poly, Team 6-25, Maness Fall 2014 Lid van Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 Leden
Één opmerking
Wyatt, thank you for the instructions. I need to replace the power switch on my Krups 963 coffee maker, but I can't find the part anywhere. Do you know where to order one from? Thanks, --Susan
susangellert - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 3,025
