Wat je nodig hebt
Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
Remove the three 60mm Phillips size 0 screws holding the top cover on.
Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
This is the most important step: and has been left unexplained!
There's a different set of instructions elsewhere on this site to remove the steam wand
Me too! Go here: Krups 963 Steamer Attachment Replacement
Grab the gasket and pull up until it is removed from the machine.
Één andere persoon heeft deze handleiding voltooid.
