Ga door naar hoofdinhoud
Konica Minolta DiMAGE Z3 LCD Screen Replacement
Wat je nodig hebt
  1. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: stap 1, afbeelding 1 van 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Open the battery chamber: stap 1, afbeelding 2 van 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
    Vraag FixBot
  2. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Insert the batteries: stap 2, afbeelding 1 van 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
    Vraag FixBot
  3. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: stap 3, afbeelding 1 van 2 Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the viewfinder cover: stap 3, afbeelding 2 van 2
    • Use a screwdriver to remove the four viewfinder cover screws.
    Vraag FixBot
  4. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove viewfinder screws: stap 4, afbeelding 1 van 1
    • Remove the 2 small screws under the viewfinder.
    Vraag FixBot
  5. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove the screen cover: stap 5, afbeelding 1 van 1
    • Remove the screen cover by applying slight pressure at the top, then pulling the screen protector away from the camera.
    • Do not apply pressure to the surface of the LCD screen or it may be permanently damaged. If fingerprints are on the LCD monitor, gently wipe with a soft, clean, dry cloth.
    Vraag FixBot
  6. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screws from the bottom panel: stap 6, afbeelding 1 van 1
    • Remove 6 screws on the bottom panel.
    Vraag FixBot
  7. Konica Minolta DiMAGE Z3 LCD Screen Replacement, Remove screw from battery chamber: stap 7, afbeelding 1 van 1
    • Remove 1 screw on the outer side of the battery chamber.
    • This will be under the rubber grip.
    Vraag FixBot
  8. Konica Minolta DiMAGE Z3 LCD Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove 1 screw inside the battery chamber.
    Vraag FixBot
  9. Konica Minolta DiMAGE Z3 LCD Screen Replacement: stap 9, afbeelding 1 van 1
    • Pull the wrist strap away from the front of the camera to remove it.
    • Then carefully pull the back casing apart from the camera.
    Vraag FixBot
  10. Konica Minolta DiMAGE Z3 LCD Screen Replacement: stap 10, afbeelding 1 van 1
    • Remove the 3 screws that attach the LCD screen to the circuit board.
    Vraag FixBot
  11. Konica Minolta DiMAGE Z3 LCD Screen Replacement: stap 11, afbeelding 1 van 1
    • Gently remove the LCD screen from the circuit board.
    • There will be a ribbon cable and some wires attached to the LCD screen.
    Vraag FixBot
  12. Konica Minolta DiMAGE Z3 LCD Screen Replacement: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Use tweezers to carefully pull the ribbon cable from the circuit board, not from the LCD screen.
    • Peel back tape on LCD screen to reveal where the wires are attached. Use tweezers to detach the wires from the LCD screen.
    Vraag FixBot
Conclusie
Hieu Ngo
431 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S7-G4, Julie Spring 2017 Lid van UMass Dartmouth, Team S7-G4, Julie Spring 2017
UMASSD-JULIE-S17S7G4
4 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 58
Altijd: 1,146
