Ga door naar hoofdinhoud
Konica Minolta DiMAGE Z3 Battery Replacement
  1. Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: stap 1, afbeelding 1 van 2 Konica Minolta DiMAGE Z3 Battery Replacement, Open the battery chamber: stap 1, afbeelding 2 van 2
    • Open the battery chamber door by sliding the door to the side of the camera to release the safety catch.
    • Lift the door up to open.
  2. Konica Minolta DiMAGE Z3 Battery Replacement, Insert the batteries: stap 2, afbeelding 1 van 1
    • Insert the four batteries inside of the battery chamber door.
    • Make sure the positive and negative battery terminals are in the correct position.
Conclusie
Hieu Ngo
431 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S7-G4, Julie Spring 2017 Lid van UMass Dartmouth, Team S7-G4, Julie Spring 2017
UMASSD-JULIE-S17S7G4
4 Leden
8 handleidingen geschreven
Één opmerking
The camera was stored with batteries inside. When opened recently, one had leaked. Now the camera will not start. Any suggestions? I tried to clean the battery compartment.. it is a bit corroded looking. Can this be repaired?
Maxine Bochnia - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 1,001
