Inleiding
Replace a faulty USB port on Komplete Audio 2 - a computer audio interface from Native Instruments.
This guide is likely to be helpful for Komplete Audio models 1 and 6 as well, since they share a similar case design.
Wat je nodig hebt
Place the device bottom up.
Using a Phillips #1 screwdriver, remove the 6 screws from the bottom cover.
Unlock the ribbon cables by pulling on the grey plastic bits of their connectors (as indicated on the second image).
Disconnect both ribbon cables by gently pulling them out of their connectors (you may need to wiggle the cables to the sides a little).
Using a Phillips #0 screwdriver, remove the 6 screws from the bottom cover.
Using a Phillips #0 screwdriver, remove the 2 screws as shown on the photos.
Gently pry on the sides of the front panel as indicated by the arrows on the first image.
Pull on the front panel upwards until it detaches from the top cover.
Desolder the USB port from the main PCB and then solder in the replacement.
Één andere persoon heeft deze handleiding voltooid.
