Ga door naar hoofdinhoud
Kolcraft Cloud Plus Seat Replacement
Wat je nodig hebt
  1. Kolcraft Cloud Plus Seat Replacement, Seat: stap 1, afbeelding 1 van 3 Kolcraft Cloud Plus Seat Replacement, Seat: stap 1, afbeelding 2 van 3 Kolcraft Cloud Plus Seat Replacement, Seat: stap 1, afbeelding 3 van 3
    • Unsnap the six buttons holding the storage basket under the seat.
  2. Kolcraft Cloud Plus Seat Replacement: stap 2, afbeelding 1 van 1
    • Unsnap the ā€œChild Trayā€ by pulling outwards on the plastic connectors on either side of the stroller. As you pull, lift upwards to completely remove the tray from its connection to the strollerā€™s frame.
  3. Kolcraft Cloud Plus Seat Replacement: stap 3, afbeelding 1 van 1
    • Remove the "Parent Tray" by pulling outwards on the plastic connectors on either side of the stroller. Lift straight up to remove completely.
  4. Kolcraft Cloud Plus Seat Replacement: stap 4, afbeelding 1 van 3 Kolcraft Cloud Plus Seat Replacement: stap 4, afbeelding 2 van 3 Kolcraft Cloud Plus Seat Replacement: stap 4, afbeelding 3 van 3
    • Unscrew the three, 14mm Phillips #2 screws on the outer frame of the stroller and repeat for the opposite side.
    • Remove the plastic washers that come off with the screws.
    • You may have to fold the stroller, then flip it over to access the screws on its underside.
  5. Kolcraft Cloud Plus Seat Replacement: stap 5, afbeelding 1 van 1
    • Unscrew the two, 14mm Phillips #2 screws on either side of the outside frame near the foot rest.
    • Remove the plastic washers.
  6. Kolcraft Cloud Plus Seat Replacement: stap 6, afbeelding 1 van 1
    • Unscrew the two, 14mm Phillips #2 on the underside of the seat and repeat for the opposite side of the stroller.
  7. Kolcraft Cloud Plus Seat Replacement: stap 7, afbeelding 1 van 2 Kolcraft Cloud Plus Seat Replacement: stap 7, afbeelding 2 van 2
    • Unscrew 14mm Phillips #2 screw on the underside of the stroller and repeat this process for the opposite side.
    • These plastic washers are circular to better fit around the frame. Remember that these locations require the circular washers.
  8. Kolcraft Cloud Plus Seat Replacement: stap 8, afbeelding 1 van 1
    • Pull the cover down the metal frame to reveal a 14mm Phillips #2 screw on either side of the inside frame.
  9. Kolcraft Cloud Plus Seat Replacement: stap 9, afbeelding 1 van 1
    • Unscrew the 14mm Phillips #2 screws located under the cover on either side of the inside frame.
  10. Kolcraft Cloud Plus Seat Replacement: stap 10, afbeelding 1 van 3 Kolcraft Cloud Plus Seat Replacement: stap 10, afbeelding 2 van 3 Kolcraft Cloud Plus Seat Replacement: stap 10, afbeelding 3 van 3
    • Using the spudger, pop out the small, white ball that's on the underside of the plastic part of the frame. Repeat this process for the opposite side.
    • Brace the spudger against the frameā€”it will provide the extra force needed to pop the white balls through their holes.
  11. Kolcraft Cloud Plus Seat Replacement: stap 11, afbeelding 1 van 2 Kolcraft Cloud Plus Seat Replacement: stap 11, afbeelding 2 van 2
    • Place the metal spudger between the plastic connector and the metal frame of the sun shade.
    • Use the spudger to pry outwards on the plastic while simultaneously pulling straight up on the metal frame of the sun shade.
    • Repeat this process for the opposite side to completely remove the seat.
    • Use one hand to brace the frame of the stroller by firmly pushing down on the plastic part of the frame.
Conclusie
Christopher Peterson
330 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-1, Forte Fall 2015 Lid van Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 1,715
