Ga door naar hoofdinhoud
Kolcraft Cloud Plus "Free-Stand" Button Replacement
Wat je nodig hebt
  1. Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: stap 1, afbeelding 1 van 2 Kolcraft Cloud Plus "Free-Stand" Button Replacement, "Free-Stand" Button: stap 1, afbeelding 2 van 2
    • Unscrew the two, 27mm Phillips #2 screws from the back of the “Free-Stand” button case.
    • You may want to flip the stroller over to access the screws.
  2. Kolcraft Cloud Plus "Free-Stand" Button Replacement: stap 2, afbeelding 1 van 1
    • Remove the back cover of the case by lifting it straight up.
  3. Kolcraft Cloud Plus "Free-Stand" Button Replacement: stap 3, afbeelding 1 van 1
    • The spring may pop out while removing the "Free Stand" button, so lift the button slowly to avoid losing the spring.
    • To access the spring, remove the red, "Free-Stand" button by lifting it straight up.
  4. Kolcraft Cloud Plus "Free-Stand" Button Replacement: stap 4, afbeelding 1 van 1
    • If the spring does not come out when you remove the "Free-Stand" button, lift the spring out of the case so it can be fixed or replaced.
Conclusie
Christopher Peterson
330 Reputatie
3 handleidingen geschreven
Cal Poly, Team 11-1, Forte Fall 2015 Lid van Cal Poly, Team 11-1, Forte Fall 2015
CPSU-FORTE-F15S11G1
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 34
Altijd: 1,294
