Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Unscrew the two 6.2 mm Phillips screws on the top half of the camera.
Unscrew top two 6.2mm Phillips screws on this side.
Unscrew the 6.2mm Phillips screw on the top right.
The front cover is now unscrewed and should be lifted evenly and removed.
Remove the two 6.2mm Phillips screws on either side of the lens securing the metal plate.
Lift metal panel and insert screwdriver through holes in panel to reach screws underneath. Remove the two 6.2mm Phillips screws.
Unscrew two 6.2mm Phillips screws on the black plate next to the lens.
At this point, all screws are removed and lens can should be carefully lifted and removed, including both plates and the plastic ring around the lens.
