Ga door naar hoofdinhoud
Kodak S100 EF Flash Capacitor Replacement
Wat je nodig hebt
  1. Kodak S100 EF Flash Capacitor Replacement, Back Cover: stap 1, afbeelding 1 van 2 Kodak S100 EF Flash Capacitor Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Remove the two 6.2mm Phillips screws on both sides of camera's back cover.
  2. Kodak S100 EF Flash Capacitor Replacement: stap 2, afbeelding 1 van 1
    • Turn camera so the bottom is facing up and the front is facing away.
    • Remove the two 6.2mm Phillips screws on the bottom back cover of the camera.
    • Back cover is now unscrewed an can be removed.
  3. Kodak S100 EF Flash Capacitor Replacement: stap 3, afbeelding 1 van 1
    • Have the back of the camera facing up.
    • Unscrew the 6.2mm Phillips screw next to the viewfinder.
    • The back cover is now unscrewed. Lift up and pull the cover off evenly.
  4. Kodak S100 EF Flash Capacitor Replacement, Flash Capacitor: stap 4, afbeelding 1 van 1
    • The capacitor is located at the bottom center of the camera.
  5. Kodak S100 EF Flash Capacitor Replacement: stap 5, afbeelding 1 van 1
    • Desolder the two connections at the top of the flash capacitor.
    • If unfamiliar with soldering, refer to the guide Hoe moet je (de-)solderen?
Conclusie
Michelle
107 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-28, Garner Spring 2011 Lid van Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 2,347
