Ga door naar hoofdinhoud
Kodak S100 EF Film Replacement
Wat je nodig hebt
  1. Kodak S100 EF Film Replacement, Film: stap 1, afbeelding 1 van 1
    • Lift up the lever from the center of the film roller.
    • Turn it clockwise to roll up the film until you feel the roller release, indicating all the film has been rolled up.
  2. Kodak S100 EF Film Replacement: stap 2, afbeelding 1 van 1
    • On the far left side on the back of the camera there is a switch that says "open."
    • Slide the button up to the top where it says "open."
    • This should pop open the door, revealing the rolled up film inside.
  3. Kodak S100 EF Film Replacement: stap 3, afbeelding 1 van 1
    • To take out the old film and insert the new, you must lift up on the film roller.
    • Pull up on the lever to pop the roller up which will release the film.
    • Remove the old roll of film and slide in the new roll.
    • Push the roller back down to secure the film.
  4. Kodak S100 EF Film Replacement: stap 4, afbeelding 1 van 1
    • To prepare the film for use, slightly pull the tail of the film out of the roll.
    • Drag the tail end of the film past the rotating column on the right side.
    • Attach the hooks at the base of the column to the holes located at the bottom of the film.
  5. Kodak S100 EF Film Replacement: stap 5, afbeelding 1 van 1
    • After the film is secured, close the camera door.
    • Make sure the lever is put back in place on the film roller.
    • Use the scroll wheel to advance the film until it is ready to take pictures.
Conclusie
Once the film is in place-to reassemble the camera-close the camera door and make sure the scroll wheel is pushed back down.
Één andere persoon heeft deze handleiding voltooid.
Michelle
107 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-28, Garner Spring 2011 Lid van Cal Poly, Team 25-28, Garner Spring 2011
CPSU-GARNER-S11S25G28
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 46
Altijd: 9,232
