Inleiding
In this guide, you will learn how to remove and replace the motherboard of your Kodak PixPro AZ251. Replacing the motherboard may be necessary if your camera does not turn on and you already tried replacing the batteries. For this replacement guide you should be comfortable using a soldering iron.
Wat je nodig hebt
Remove a total of four 5mm JIS #000 screws from around the camera:
Two screws from the right side.
Two screws from the left side.
Remove these three JIS #000 screws from the control board:
5mm screw.
4mm screw.
2mm screw.
5 andere personen hebben deze handleiding voltooid.
