Ga door naar hoofdinhoud
Kodak Easyshare Z981 LCD Screen Replacement
Wat je nodig hebt
  1. Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 1 van 2 Kodak Easyshare Z981 LCD Screen Replacement, LCD Screen: stap 1, afbeelding 2 van 2
    • Open the battery cover and remove batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Kodak Easyshare Z981 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Use a 00 Phillips-Head screwdriver to remove screws:
    • Remove the 3 mm screws from the camera
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 LCD Screen Replacement: stap 3, afbeelding 1 van 1
    • Start from a corner and gently remove the cover.
    • The cover will easily lift off, so not much pressure is required.
    • Make sure to gently remove the bottom cover in order to avoid breaking the plastic.
  4. Kodak Easyshare Z981 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Kodak Easyshare Z981 LCD Screen Replacement: stap 4, afbeelding 2 van 2
    $5.49
    Koop
    • Use a Phillips #00 Screwdriver to remove the 4 mm screws from each side of the back cover of the camera.
    • Two (2) screws are located in the left side of the device
    • Two (2) screws are locatecd in the right side of the device
  5. Kodak Easyshare Z981 LCD Screen Replacement: stap 5, afbeelding 1 van 2 Kodak Easyshare Z981 LCD Screen Replacement: stap 5, afbeelding 2 van 2
    • Insert the Plastic Opening Tool in to the crevices of back cover and gently apply pressure
    • Be gentle while removing the cover, to avoid cracking the case
  6. Kodak Easyshare Z981 LCD Screen Replacement: stap 6, afbeelding 1 van 2 Kodak Easyshare Z981 LCD Screen Replacement: stap 6, afbeelding 2 van 2
    • Once the back cover is removed locate the four 3mm screws holding the screen and the metal brace to the circuit board
  7. Kodak Easyshare Z981 LCD Screen Replacement: stap 7, afbeelding 1 van 3 Kodak Easyshare Z981 LCD Screen Replacement: stap 7, afbeelding 2 van 3 Kodak Easyshare Z981 LCD Screen Replacement: stap 7, afbeelding 3 van 3
    Koop
    • Gently lift up the metal brace and use a pair to disconnect the ribbon cable connecter
    • Use Tweezers to disconnect the ribbon cable connector.
    • Once disconnected remove the screen brace from the circuit board
    • Use extreme caution when removing the LCD brace pulling the brace may tear the cable
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Daniel Ramirez
152 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 581
