Wat je nodig hebt
Open the battery cover and remove the AA batteries from the camera if any are inserted.
Gereedschap gebruikt in deze stap:Phillips #00 Screwdriver$5.49
Remove screws using a 00 Phillips-Head screwdriver:
Eight (8) 3mm screws on the lower portion of the camera
Four (4) on the bottom of the camera
Four (4) on the inside of the battery cover
Four (4) 6mm screws on the sides of the camera (two on each side)
Bijna klaar!
Conclusie
