Ga door naar hoofdinhoud
Kodak Easyshare Z981 Flash Button Replacement
Wat je nodig hebt
  1. Kodak Easyshare Z981 Flash Button Replacement, Flash Button: stap 1, afbeelding 1 van 2 Kodak Easyshare Z981 Flash Button Replacement, Flash Button: stap 1, afbeelding 2 van 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Flash Button Replacement: stap 2, afbeelding 1 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 2, afbeelding 2 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Remove screws using a 00 Phillips-Head screwdriver:
    • Eight (8) 3mm screws on the lower portion of the camera
    • Four (4) on the bottom of the camera
    • Four (4) on the inside of the battery cover
    • Four (4) 6mm screws on the sides of the camera (two on each side)
  3. Kodak Easyshare Z981 Flash Button Replacement: stap 3, afbeelding 1 van 1
    • Start from a corner and gently remove the bottom of the camera.
    • The cover will easily lift off, so not much pressure is required.
  4. Kodak Easyshare Z981 Flash Button Replacement: stap 4, afbeelding 1 van 2 Kodak Easyshare Z981 Flash Button Replacement: stap 4, afbeelding 2 van 2
    • Use a Plastic Opening Tool to remove the back of the camera
  5. Kodak Easyshare Z981 Flash Button Replacement: stap 5, afbeelding 1 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 5, afbeelding 2 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 5, afbeelding 3 van 3
    Koop
    • Remove the four (4) 3mm screws attaching the LCD screen to the circuit board.
    • Use Tweezers to carefully detach the ribbon cable
    • Use extreme caution on this step, as the ribbon cable is very fragile and can rip very easily.
  6. Kodak Easyshare Z981 Flash Button Replacement: stap 6, afbeelding 1 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 6, afbeelding 2 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 6, afbeelding 3 van 3
    • Open the flash compartment and remove two (2) 3mm screws.
  7. Kodak Easyshare Z981 Flash Button Replacement: stap 7, afbeelding 1 van 2 Kodak Easyshare Z981 Flash Button Replacement: stap 7, afbeelding 2 van 2
    • Use a Plastic Opening Tool to carefully remove the top of the camera.
    • Use caution when removing the top of the camera
  8. Kodak Easyshare Z981 Flash Button Replacement: stap 8, afbeelding 1 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 8, afbeelding 2 van 3 Kodak Easyshare Z981 Flash Button Replacement: stap 8, afbeelding 3 van 3
    • Remove four (4) 3mm screws from the circuit board underneath the button set.
    • Gently move the circuit board aside.
    • Gently move aside the metal sheet.
  9. Kodak Easyshare Z981 Flash Button Replacement: stap 9, afbeelding 1 van 2 Kodak Easyshare Z981 Flash Button Replacement: stap 9, afbeelding 2 van 2
    Koop
    • Use Tweezers to carefully remove the flash button.
    • The button should simply pop out when light pressure is applied.
Conclusie
Olivia Boyna
509 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 700
