Ga door naar hoofdinhoud
Kodak Easyshare Z981 Bottom Panel Replacement
Wat je nodig hebt
  1. Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Kodak Easyshare Z981 Bottom Panel Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Open the battery cover and remove the AA batteries from the camera if any are inserted.
  2. Kodak Easyshare Z981 Bottom Panel Replacement: stap 2, afbeelding 1 van 3 Kodak Easyshare Z981 Bottom Panel Replacement: stap 2, afbeelding 2 van 3 Kodak Easyshare Z981 Bottom Panel Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Use a 00 Phillips-Head screwdriver
    • Remove the 3 mm screws from the camera.
    • Four (4) screws are in the bottom of the device
    • Four (4) screws are inside the battery cover
  3. Kodak Easyshare Z981 Bottom Panel Replacement: stap 3, afbeelding 1 van 1
    • Start from a corner and gently remove the bottom cover.
    • The cover will easily lift off, so not much pressure is required.
    • Be gentle while removing the cover, to avoid breaking the plastic
  4. Kodak Easyshare Z981 Bottom Panel Replacement: stap 4, afbeelding 1 van 3 Kodak Easyshare Z981 Bottom Panel Replacement: stap 4, afbeelding 2 van 3 Kodak Easyshare Z981 Bottom Panel Replacement: stap 4, afbeelding 3 van 3
    • Remove the bottom of the battery cover first, and then the top.
    • The hinge is simple, the screwdriver is no longer necessary.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Olivia Boyna
509 Reputatie
3 handleidingen geschreven
6 opmerkingen
where can i buy it?
Lizette Nin - Antwoord
PLEASE help? I can't find this part anywhere?
thecarlisles - Antwoord
Did anyone ever find the parts to complete this task? It's exactly what I need to do but cant find the bottom plate anywhere.
Billy T - Antwoord
I need the bottom panel also. If anyone knows where to purchase it please email me kpw1god@yahoo.com
kpw1god - Antwoord
I HAVE THE SAME QUESTION. WHERE  ARE THE PARTS BOUGHT??????? WHY PUT THIS OUT  IF U CAN’T BUY THE PARTS?? bILL     RENTMRBILL@YAHOO.COM
rentmrbill - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 2,236
