Ga door naar hoofdinhoud
Kodak Easyshare C813 Lens Replacement
Wat je nodig hebt
  1. Kodak Easyshare C813 Lens Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Kodak Easyshare C813 Lens Replacement: stap 2, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 2, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 2, afbeelding 3 van 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Kodak Easyshare C813 Lens Replacement, Back Cover: stap 3, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
  4. Kodak Easyshare C813 Lens Replacement: stap 4, afbeelding 1 van 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Kodak Easyshare C813 Lens Replacement: stap 5, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 5, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 5, afbeelding 3 van 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Kodak Easyshare C813 Lens Replacement: stap 6, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 6, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 6, afbeelding 3 van 3
    Phillips #00 Screwdriver
    $5.49
    Koop
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Kodak Easyshare C813 Lens Replacement: stap 7, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 7, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 7, afbeelding 3 van 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Kodak Easyshare C813 Lens Replacement: stap 8, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 8, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 8, afbeelding 3 van 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
  9. Kodak Easyshare C813 Lens Replacement, Front Cover: stap 9, afbeelding 1 van 2 Kodak Easyshare C813 Lens Replacement, Front Cover: stap 9, afbeelding 2 van 2
    • Open the battery door.
    The battery door on my easyshare c813 is broken. How can i get a replacement door?
    paul chadwell - Antwoord
  10. Kodak Easyshare C813 Lens Replacement: stap 10, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 10, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 10, afbeelding 3 van 3
    • Use the plastic opening tool to lift the casing around the shutter button.
    • Gently remove the front cover from the device.
  11. Kodak Easyshare C813 Lens Replacement: stap 11, afbeelding 1 van 1
    • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
    • To discharge the capacitor follow this guide.
  12. Kodak Easyshare C813 Lens Replacement, LCD: stap 12, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement, LCD: stap 12, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement, LCD: stap 12, afbeelding 3 van 3
    • Once the front cover is removed, the battery door maybe closed for convenience.
    • Locate the exposed portion of the LCD screen.
    • Use a wedge to free the LCD screen from the medal housing.
    • Do not pull the screen away completely, it is still attached to the logic board via the yellow cable.
  13. Kodak Easyshare C813 Lens Replacement: stap 13, afbeelding 1 van 1
    • Remove the screw at the upper right corner of the metal housing.
  14. Kodak Easyshare C813 Lens Replacement: stap 14, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 14, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 14, afbeelding 3 van 3
    • Locate the 2 solder joints holding down the medal housing.
    • Remove the solder.
    • Place wick on solder.
    • Place solder iron on wick
    • The wick should be sandwiched between the iron and the solder.
  15. Kodak Easyshare C813 Lens Replacement: stap 15, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 15, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 15, afbeelding 3 van 3
    • Peel back the black tape from the metal housing.
    • Lift the metal housing from the left so that it hinges on its right side.
    • The metal housing is still loosely attached on its right side.
  16. Kodak Easyshare C813 Lens Replacement: stap 16, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 16, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 16, afbeelding 3 van 3
    • Locate black tab holding the LCD screen connector in the port.
    • Use wedge or fingernail to lift the black tab.
    • Pull the the LCD screen connector out of the port.
  17. Kodak Easyshare C813 Lens Replacement, Logic Board: stap 17, afbeelding 1 van 1
    • Remove the medal housing from the logic board by carefully peeling the yellow tape off of the metal housing.
  18. Kodak Easyshare C813 Lens Replacement: stap 18, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 18, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 18, afbeelding 3 van 3
    • Locate the 2 screws on the yellow tape.
    • Remove the 2 screws.
    • Remove the yellow tape.
  19. Kodak Easyshare C813 Lens Replacement: stap 19, afbeelding 1 van 2 Kodak Easyshare C813 Lens Replacement: stap 19, afbeelding 2 van 2
    • Locate the 2 solder joints near the shutter button.
    • Remove the solder on both joints with the wick and soldering iron in the same manner as Step 11.
  20. Kodak Easyshare C813 Lens Replacement: stap 20, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 20, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 20, afbeelding 3 van 3
    • Turn the camera over.
    • Remove the screw holding the small green board.
    • Lift the small green board.
    • The small green board is still attached to the logic board via wires.
  21. Kodak Easyshare C813 Lens Replacement: stap 21, afbeelding 1 van 1
    • Desolder the remaining 20 solder joints connecting the logic board to the camera.
  22. Kodak Easyshare C813 Lens Replacement: stap 22, afbeelding 1 van 2 Kodak Easyshare C813 Lens Replacement: stap 22, afbeelding 2 van 2
    • Locate the black tab holding the yellow cable in place.
    • Use a plastic opening tool or fingernail to lift the black tab.
    • Pull the yellow cable from the port.
  23. Kodak Easyshare C813 Lens Replacement: stap 23, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement: stap 23, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement: stap 23, afbeelding 3 van 3
    • Use a plastic opening tool to lift the board from the camera.
    • Continue to remove the board completely.
  24. Kodak Easyshare C813 Lens Replacement, Lens: stap 24, afbeelding 1 van 3 Kodak Easyshare C813 Lens Replacement, Lens: stap 24, afbeelding 2 van 3 Kodak Easyshare C813 Lens Replacement, Lens: stap 24, afbeelding 3 van 3
    • Remove the 3 screws securing the lens to the camera.
    • Gently remove the lens from the remaining casing.
Conclusie
Susan Marano
336 Reputatie
7 handleidingen geschreven
Cal Poly, Team 24-22, Regan Spring 2010 Lid van Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Leden
20 handleidingen geschreven
Één opmerking
Great, please I need help on my Kodak easyshare z1085 IS, other things is working, but always black can't see anything through the screen
Adeniyi Egbemode - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 7,786
