Inleiding
The lens cover protects the lens of the camera from being scratched or damaged while not in use. If the cover breaks or cracks and a replacement needs to be done, you can follow the steps in the following guide.
  1. Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling. Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
    • Remove lens cover from the camera by squeezing the protruding button on each side of the cover and pulling.
  2. Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string. Push up so that the string starts to come out of the top of the loop. Grab the string from above the loop and pull.
    • Pull the lens cover string toward the ground so that the loop underneath the metal slab is on top of the cover string.
    • Push up so that the string starts to come out of the top of the loop.
    • Grab the string from above the loop and pull.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
    Ooit iets gerepareerd? Je bent een genie.
    Deel je reparatie met #ImAGenius
    We zijn allemaal genieën
  4. Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further. Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
    • Feed the string on top into the metal slab while pulling the loop toward you until the plastic piece stops you from pulling any further.
  5. Separate the two pieces of the loop and pull the lens cover up in between them. Separate the two pieces of the loop and pull the lens cover up in between them. Separate the two pieces of the loop and pull the lens cover up in between them.
    • Separate the two pieces of the loop and pull the lens cover up in between them.
  6. Pull the lens cover and the sting will come out of the metal slab. Pull the lens cover and the sting will come out of the metal slab. Pull the lens cover and the sting will come out of the metal slab.
    • Pull the lens cover and the sting will come out of the metal slab.
Conclusie
Kirsten Price
343 Reputatie
6 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 361
