Ga door naar hoofdinhoud
Kodak EasyShare Z1015 IS SD Memory Card Replacement
Wat je nodig hebt
  1. Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: stap 1, afbeelding 1 van 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement, SD Memory Card: stap 1, afbeelding 2 van 2
    • In order to remove the SD memory card, you will first need to open up the cover. To open the cover, slide the latch holding the cover in place to the left.
    • Remove your hand from the latch and the cover should pop open. The SD memory card is located near the top above the battery. As shown in the final picture of this step.
  2. Kodak EasyShare Z1015 IS SD Memory Card Replacement: stap 2, afbeelding 1 van 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: stap 2, afbeelding 2 van 2
    • After locating the SD card, gently push down on the card and release. This will cause the SD card to pop out of its position in the camera as shown in the second picture of this step.
  3. Kodak EasyShare Z1015 IS SD Memory Card Replacement: stap 3, afbeelding 1 van 2 Kodak EasyShare Z1015 IS SD Memory Card Replacement: stap 3, afbeelding 2 van 2
    • After removing the SD card from its locked position, gently pull the SD card out from the container to successfully remove it from the camera.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
katie newman
30 Reputatie
3 handleidingen geschreven
Cal Poly, Team 5-16, Maness Fall 2010 Lid van Cal Poly, Team 5-16, Maness Fall 2010
CPSU-MANESS-F10S5G16
4 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 2,796
