Ga door naar hoofdinhoud
Kodak EasyShare V570 Case Replacement
Wat je nodig hebt
  1. Kodak EasyShare V570 Case Replacement, Case: stap 1, afbeelding 1 van 2 Kodak EasyShare V570 Case Replacement, Case: stap 1, afbeelding 2 van 2
    • Here is the front, back, and right side of the camera.
  2. Kodak EasyShare V570 Case Replacement: stap 2, afbeelding 1 van 3 Kodak EasyShare V570 Case Replacement: stap 2, afbeelding 2 van 3 Kodak EasyShare V570 Case Replacement: stap 2, afbeelding 3 van 3
    • There are going to be four #000 screws on the left side of the camera.
    • Remove the four corner screws using a Philips #000 Screwdriver.
    • On the right side of the camera, remove the two Phillips #000 screws at the bottom.
    • On the underside of the camera, remove the three Phillips #000 screws.
  3. Kodak EasyShare V570 Case Replacement: stap 3, afbeelding 1 van 3 Kodak EasyShare V570 Case Replacement: stap 3, afbeelding 2 van 3 Kodak EasyShare V570 Case Replacement: stap 3, afbeelding 3 van 3
    • As soon as all the screws from the casing are removed, use the iFixit opening pick to slide around the border.
    • If the cover appears loose, try to take it off (with your fingers) while slightly wiggling it, and it should detach.
  4. Kodak EasyShare V570 Case Replacement: stap 4, afbeelding 1 van 2 Kodak EasyShare V570 Case Replacement: stap 4, afbeelding 2 van 2
    • Here is what the camera looks like with both of the covers taken off.
    • The T-W button is upside down.
    • To put the top and back camera covers back on, follow the steps but in reverse.
Eindstreep
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 100
