Ga door naar hoofdinhoud
Kodak EasyShare V570 Battery Replacement
  1. Kodak EasyShare V570 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Kodak EasyShare V570 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Kodak EasyShare V570 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Turn off your camera before beginning the replacement.
    • Take a finger or two and slide back the compartment where the battery will be and lift it up.
  2. Kodak EasyShare V570 Battery Replacement: stap 2, afbeelding 1 van 2 Kodak EasyShare V570 Battery Replacement: stap 2, afbeelding 2 van 2
    • Be careful when pulling back the brown tap it can be a little tricky.
    • Push back the brown tab with your finger.
  3. Kodak EasyShare V570 Battery Replacement: stap 3, afbeelding 1 van 3 Kodak EasyShare V570 Battery Replacement: stap 3, afbeelding 2 van 3 Kodak EasyShare V570 Battery Replacement: stap 3, afbeelding 3 van 3
    • Take out the old battery from its compartment with 2 fingers
    • If it doesn't come out that way turn the camera towards you and let it slide out onto your hand.
  4. Kodak EasyShare V570 Battery Replacement: stap 4, afbeelding 1 van 2 Kodak EasyShare V570 Battery Replacement: stap 4, afbeelding 2 van 2
    • Insert the new battery by pulling down the brown mark.
    • Grab the new battery and insert it into the battery compartment
    • Please do not use force while inserting the new battery.
    • Make sure that the battery has its corner facing down and inwards at the camera.
  5. Kodak EasyShare V570 Battery Replacement: stap 5, afbeelding 1 van 3 Kodak EasyShare V570 Battery Replacement: stap 5, afbeelding 2 van 3 Kodak EasyShare V570 Battery Replacement: stap 5, afbeelding 3 van 3
    • Be careful to not use too much force.
    • Lightly push the cover down and slide it inward.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 102
