Ga door naar hoofdinhoud
Kodak EasyShare M381 Button Replacement
Wat je nodig hebt
  1. Kodak EasyShare M381 Button Replacement, Battery: stap 1, afbeelding 1 van 2 Kodak EasyShare M381 Button Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Button Replacement: stap 2, afbeelding 1 van 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Button Replacement, Back Panel Frame: stap 3, afbeelding 1 van 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: stap 3, afbeelding 2 van 3 Kodak EasyShare M381 Button Replacement, Back Panel Frame: stap 3, afbeelding 3 van 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Button Replacement: stap 4, afbeelding 1 van 2 Kodak EasyShare M381 Button Replacement: stap 4, afbeelding 2 van 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Button Replacement, Button: stap 5, afbeelding 1 van 1
    • Carefully pick up frame and push upward on buttons.
  6. Kodak EasyShare M381 Button Replacement: stap 6, afbeelding 1 van 1
    • Clean and replace as needed.
    • A microfiber cloth, or any other type of electronic cloth may be used to clean them if desire.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 260
