Ga door naar hoofdinhoud
Kodak EasyShare M381 Battery Latch Replacement
Wat je nodig hebt
  1. Kodak EasyShare M381 Battery Latch Replacement, Battery: stap 1, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement, Battery: stap 1, afbeelding 2 van 2
    • First, press in and slide forward the battery latch as indicated by the arrow.
  2. Kodak EasyShare M381 Battery Latch Replacement: stap 2, afbeelding 1 van 1
    • Press down on battery until you hear a click and release it. Battery should easily slide out.
  3. Kodak EasyShare M381 Battery Latch Replacement, Back Panel Frame: stap 3, afbeelding 1 van 3 Kodak EasyShare M381 Battery Latch Replacement, Back Panel Frame: stap 3, afbeelding 2 van 3 Kodak EasyShare M381 Battery Latch Replacement, Back Panel Frame: stap 3, afbeelding 3 van 3
    • Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
    • Using a magnetized surface to keep from losing screws may be very helpful.
  4. Kodak EasyShare M381 Battery Latch Replacement: stap 4, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 4, afbeelding 2 van 2
    • Using both hands, carefully pull the frame apart from the camera.
  5. Kodak EasyShare M381 Battery Latch Replacement, Screen: stap 5, afbeelding 1 van 1
    • Remove the two 3.85 mm screws on the bottom right of the camera, as indicated.
  6. Kodak EasyShare M381 Battery Latch Replacement: stap 6, afbeelding 1 van 1
    • Remove dial button located on top of camera, by gently pulling up.
  7. Kodak EasyShare M381 Battery Latch Replacement: stap 7, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 7, afbeelding 2 van 2
    • Starting at one side, carefully work the chrome frame off of the camera itself.
    • Be careful not to disturb the shutter or flash buttons on top of the camera.
  8. Kodak EasyShare M381 Battery Latch Replacement: stap 8, afbeelding 1 van 1
    • On the right side of the camera, locate and remove the two 3.25 mm screws as highlighted.
  9. Kodak EasyShare M381 Battery Latch Replacement: stap 9, afbeelding 1 van 3 Kodak EasyShare M381 Battery Latch Replacement: stap 9, afbeelding 2 van 3 Kodak EasyShare M381 Battery Latch Replacement: stap 9, afbeelding 3 van 3
    • Carefully lift the motherboard panel up, pulling towards the left. Make sure you do not rip the blue ribbon.
    • Using a plastic opening tool, gently lift up on the ribbon fastener until it is in an upright position.
    • Slide panel away from camera.
  10. Kodak EasyShare M381 Battery Latch Replacement: stap 10, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 10, afbeelding 2 van 2
    • Using a plastic opening tool, gently lift ribbon clamp as indicated to remove the screen ribbon from the motherboard.
    • Screen should now be detached. Gently lift it away from the base of the camera.
  11. Kodak EasyShare M381 Battery Latch Replacement, Battery Latch: stap 11, afbeelding 1 van 3 Kodak EasyShare M381 Battery Latch Replacement, Battery Latch: stap 11, afbeelding 2 van 3 Kodak EasyShare M381 Battery Latch Replacement, Battery Latch: stap 11, afbeelding 3 van 3
    • Locate and remove selector dial on the top of the camera.
    • This should free the chrome mid-frame that encompasses the camera. Carefully lift and remove it as well.
  12. Kodak EasyShare M381 Battery Latch Replacement: stap 12, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 12, afbeelding 2 van 2
    • Carefully lift and remove front covered panel from the camera.
  13. Kodak EasyShare M381 Battery Latch Replacement: stap 13, afbeelding 1 van 1
    • Locate metal battery panel. Carefully lift and remove it as indicated.
  14. Kodak EasyShare M381 Battery Latch Replacement: stap 14, afbeelding 1 van 3 Kodak EasyShare M381 Battery Latch Replacement: stap 14, afbeelding 2 van 3 Kodak EasyShare M381 Battery Latch Replacement: stap 14, afbeelding 3 van 3
    • Locate the four 3.25 mm screws holding the metal lens panel in place, and remove them.
    • You should then be able to lift and remove the metal paneling. This will now expose the pin holding the battery latch in place as indicated.
  15. Kodak EasyShare M381 Battery Latch Replacement: stap 15, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 15, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Keeping the battery latch panel closed and in place, use a straightened paper clip (or similar tool) to push the pin out of the hole.
    • Use tweezers to securely remove pin.
    • Placing the pin on a magnet pad or piece of tape is recommended to prevent from losing it.
    • The spring is under tension. When performing this step, it may fly out if not done correctly. Take proper precautions to minimize injury and loss of parts.
  16. Kodak EasyShare M381 Battery Latch Replacement: stap 16, afbeelding 1 van 2 Kodak EasyShare M381 Battery Latch Replacement: stap 16, afbeelding 2 van 2
    • The latch can now easily be pulled out of place and removed.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 316
