Inleiding
This will teach you how to remove the capacitor in your Kodak EasyShare LS743.
Onderdelen
Geen onderdelen opgegeven.
Using a Phillips #00 screwdriver, remove two (5.39 mm) screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located throughout the camera.
One (6.25 mm) screw is located on the top right corner, right to the "OK" button.
Four (4.45 mm) screws are on the bottom of the camera.
Two (2.95 mm) screws are on the left side of the camera, above the USB Port.
Connect the two capacitor wires briefly with a pair of metal tweezers to discharge the capacitor. You may see a small spark.
Remove eight screws using a Phillips #00 screwdriver.
Two (4.31 mm) screws are in the front of the camera.
Two (3.30 mm) screws are located in the bottom of the camera.
Four (3 x 3.33 mm and 1 x 4.34 mm) screws are in the back of the camera.
Één andere persoon heeft deze handleiding voltooid.
