Inleiding
Remove damaged case and replace with new casing.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Using a Phillips #00 screwdriver, remove two (5.39 mm) screws next to the battery slot.
Remove the metal piece holding down the lanyard, then remove the lanyard.
Using a Phillips #00 screwdriver, remove seven screws located throughout the camera.
One (6.25 mm) screw is located on the top right corner, right to the "OK" button.
Four (4.45 mm) screws are on the bottom of the camera.
Two (2.95 mm) screws are on the left side of the camera, above the USB Port.
Één andere persoon heeft deze handleiding voltooid.
