Ga door naar hoofdinhoud
Kodak EasyShare LS743 Battery Door Replacement
Wat je nodig hebt
  1. Kodak EasyShare LS743 Battery Door Replacement, Battery: stap 1, afbeelding 1 van 1
    • Using your fingernail, open the battery cover.
  2. Kodak EasyShare LS743 Battery Door Replacement: stap 2, afbeelding 1 van 1
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 1 van 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 2 van 3 Kodak EasyShare LS743 Battery Door Replacement, Kodak EasyShare LS743 Camera Case Disassembly: stap 3, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove two 5.39 mm screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Kodak EasyShare LS743 Battery Door Replacement: stap 4, afbeelding 1 van 3 Kodak EasyShare LS743 Battery Door Replacement: stap 4, afbeelding 2 van 3 Kodak EasyShare LS743 Battery Door Replacement: stap 4, afbeelding 3 van 3
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One 6.25 mm screw is located on the top right corner, right to the "OK" button.
    • Four 4.45 mm screws are on the bottom of the camera.
    • Two 2.95 mm screws are on the left side of the camera, above the USB port.
  5. Kodak EasyShare LS743 Battery Door Replacement: stap 5, afbeelding 1 van 2 Kodak EasyShare LS743 Battery Door Replacement: stap 5, afbeelding 2 van 2
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Kodak EasyShare LS743 Battery Door Replacement, Battery Door: stap 6, afbeelding 1 van 2 Kodak EasyShare LS743 Battery Door Replacement, Battery Door: stap 6, afbeelding 2 van 2
    • Remove loose battery door.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Odessa
55 Reputatie
2 handleidingen geschreven
Cal Poly, Team 2-8, Johann Summer 2010 Lid van Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Leden
16 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 1,736
