Inleiding
Use this guide to remove and replace front and back casing.
Onderdelen
Geen onderdelen nodig.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
    • Remove 7 screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
Conclusie
Taggart Ashby
315 Reputatie
4 handleidingen geschreven
Cal Poly, Team 26-19, Regan Spring 2010 Lid van Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Leden
7 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 4
Altijd: 2,112
