Ga door naar hoofdinhoud
Kodak EasyShare C713 LCD Replacement
Wat je nodig hebt
  1. Kodak EasyShare C713 LCD Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: stap 2, afbeelding 1 van 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: stap 3, afbeelding 1 van 3 Kodak EasyShare C713 LCD Replacement, Outer Case: stap 3, afbeelding 2 van 3 Kodak EasyShare C713 LCD Replacement, Outer Case: stap 3, afbeelding 3 van 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: stap 4, afbeelding 1 van 3 Kodak EasyShare C713 LCD Replacement: stap 4, afbeelding 2 van 3 Kodak EasyShare C713 LCD Replacement: stap 4, afbeelding 3 van 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: stap 5, afbeelding 1 van 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: stap 6, afbeelding 1 van 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: stap 7, afbeelding 1 van 2 Kodak EasyShare C713 LCD Replacement: stap 7, afbeelding 2 van 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: stap 8, afbeelding 1 van 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: stap 9, afbeelding 1 van 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: stap 10, afbeelding 1 van 1
    • Remove the LCD ribbon cable from inside the black tab.
Conclusie
6 andere personen hebben deze handleiding voltooid.
Taggart Ashby
354 Reputatie
4 handleidingen geschreven
Cal Poly, Team 26-19, Regan Spring 2010 Lid van Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Leden
14 handleidingen geschreven
2 opmerkingen
Thank you... i fixed my old camera lcd.
anthoxman - Antwoord
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 5,252
