Inleiding
Replacing the capacitor.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
      • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
    • Remove 7 screws from the outer case with a Phillips #00.
      • All screws are 4.45mm.
      • There are 2 screws on the port side.
      • There are 2 screws on starboard side.
      • There are 3 screws on the bottom.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
    • Desolder points connecting capacitor to circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Scott DiGirolamo
28 Reputatie
1 Handleiding geschreven
Cal Poly, Team 26-19, Regan Spring 2010 Lid van Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Leden
7 handleidingen geschreven
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 2
Afgelopen 30 Dagen: 6
Altijd: 3,841
