Ga door naar hoofdinhoud
Kodak EasyShare C713 Battery Door Replacement
Wat je nodig hebt
  1. Kodak EasyShare C713 Battery Door Replacement, Batteries: stap 1, afbeelding 1 van 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Battery Door Replacement: stap 2, afbeelding 1 van 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Battery Door Replacement, Outer Case: stap 3, afbeelding 1 van 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: stap 3, afbeelding 2 van 3 Kodak EasyShare C713 Battery Door Replacement, Outer Case: stap 3, afbeelding 3 van 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Battery Door Replacement: stap 4, afbeelding 1 van 3 Kodak EasyShare C713 Battery Door Replacement: stap 4, afbeelding 2 van 3 Kodak EasyShare C713 Battery Door Replacement: stap 4, afbeelding 3 van 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Battery Door Replacement, Battery Door: stap 5, afbeelding 1 van 2 Kodak EasyShare C713 Battery Door Replacement, Battery Door: stap 5, afbeelding 2 van 2
    • Make sure the battery door is open.
    • Using a pair of tweezers, remove the metal rod at the junction of the battery door and the inner camera case.
    • This rod serves as the hinge for the door.
    • Make sure not to lose the battery door spring which may fall when the rod is removed.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Trevor DeVore
17 Reputatie
1 Handleiding geschreven
Cal Poly, Team 26-19, Regan Spring 2010 Lid van Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Leden
14 handleidingen geschreven
Één opmerking
Where do I buy a new battery door. Cheers, Peter
Peter - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 11
Altijd: 5,163
