Ga door naar hoofdinhoud
Kodak EasyShare C195 Memory Card Replacement
Wat je nodig hebt
  1. Kodak EasyShare C195 Memory Card Replacement, Memory Card: stap 1, afbeelding 1 van 3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: stap 1, afbeelding 2 van 3 Kodak EasyShare C195 Memory Card Replacement, Memory Card: stap 1, afbeelding 3 van 3
    • First, access the slide door on the bottom left corner of the camera. To open, push down and to the left.
  2. Kodak EasyShare C195 Memory Card Replacement: stap 2, afbeelding 1 van 3 Kodak EasyShare C195 Memory Card Replacement: stap 2, afbeelding 2 van 3 Kodak EasyShare C195 Memory Card Replacement: stap 2, afbeelding 3 van 3
    • The memory card slot is located just below the batteries.
    • To insert the memory card, make sure the writing is facing the batteries, and the cut off corner is at the top right. Put the card into the slot and push until you hear a click.
    • You do not need to remove the batteries to insert the memory card.
  3. Kodak EasyShare C195 Memory Card Replacement: stap 3, afbeelding 1 van 1
    • This is what the memory card should look like when finished.
Conclusie
To remove, push the memory card until you feel a click. The card should pop out.
Alyssa
81 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-22, Amido Spring 2012 Lid van Cal Poly, Team 6-22, Amido Spring 2012
CPSU-AMIDO-S12S6G22
4 Leden
8 handleidingen geschreven
2 opmerkingen
Hi. I purchased a new memory card. When inserted into the camera, I can’t take a picture because the camera states internal memory full. What do I do??
katherine skorich-nelson - Antwoord
Bought a new memory card. Cannot take pictures because the screen states "internal memory full”. What do I do?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 22
Altijd: 2,463
