Ga door naar hoofdinhoud
Kobo Arc K107 USB Replacement
Wat je nodig hebt
  1. Kobo Arc K107 USB Replacement, Battery: stap 1, afbeelding 1 van 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 USB Replacement: stap 2, afbeelding 1 van 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 USB Replacement: stap 3, afbeelding 1 van 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 USB Replacement: stap 4, afbeelding 1 van 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 USB Replacement, USB: stap 5, afbeelding 1 van 1
    • Remove the motherboard from the outer case.
  6. Kobo Arc K107 USB Replacement: stap 6, afbeelding 1 van 1
    • Detach the USB cable from the motherboard.
    • Remove the USB port from the tablet.
Conclusie
Ray Starpoli
169 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 319
