Ga door naar hoofdinhoud
Kobo Arc K107 Screen Replacement
Wat je nodig hebt
  1. Kobo Arc K107 Screen Replacement, Battery: stap 1, afbeelding 1 van 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Screen Replacement: stap 2, afbeelding 1 van 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Screen Replacement: stap 3, afbeelding 1 van 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Screen Replacement: stap 4, afbeelding 1 van 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Screen Replacement, Speaker: stap 5, afbeelding 1 van 2 Kobo Arc K107 Screen Replacement, Speaker: stap 5, afbeelding 2 van 2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Screen Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the speakers from the tablet.
  7. Kobo Arc K107 Screen Replacement, Screen: stap 7, afbeelding 1 van 2 Kobo Arc K107 Screen Replacement, Screen: stap 7, afbeelding 2 van 2
    • Wedge a nylon spudger between the screen and the tablet.
    • Slide the spudger around the edges of the screen and remove it from the device.
Conclusie
Stephen Pehl
303 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Lid van UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 14
Altijd: 370
