Ga door naar hoofdinhoud
KitchenAid Professional 600 Top Cover Replacement
Wat je nodig hebt
  1. KitchenAid Professional 600 Top Cover Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
  2. KitchenAid Professional 600 Top Cover Replacement: stap 2, afbeelding 1 van 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
  3. KitchenAid Professional 600 Top Cover Replacement: stap 3, afbeelding 1 van 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Luke
1.380 Reputatie
5 handleidingen geschreven
Cal Poly, Team 25-4, Maness Spring 2016 Lid van Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 Leden
18 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 41
Altijd: 2,607
