Inleiding
Outline what you are going to teach someone how to do.
Wat je nodig hebt
Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
Remove the silver band.
Locate the selector switch.
Remove the two Phillips #2 screws holding the selector switch in place.
Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
4 opmerkingen
anyone know where I can get the hall effect sensor receiver that is on the motor shaft? Somehow it's missing?
I accidentally pluged my 110v mixer to 220v. Now, what are the possible parts that i need to change? How can i check if the motor is busted?
