Ga door naar hoofdinhoud
KitchenAid KSM150PSER Power Cord Replacement
Wat je nodig hebt
  1. KitchenAid KSM150PSER Power Cord Replacement, Power Cord: stap 1, afbeelding 1 van 2 KitchenAid KSM150PSER Power Cord Replacement, Power Cord: stap 1, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the 10mm screw on the back cover by rotating it counterclockwise.
    • The back cover is now free. Remove it by pulling back and up on the cover.
  2. KitchenAid KSM150PSER Power Cord Replacement: stap 2, afbeelding 1 van 2 KitchenAid KSM150PSER Power Cord Replacement: stap 2, afbeelding 2 van 2
    • Using a Phillips #2 screwdriver, remove the 5mm screws holding the trimband to the top housing by rotating them counterclockwise.
    • Pull the trimband off the housing by grabbing each side and pulling it off the front.
  3. KitchenAid KSM150PSER Power Cord Replacement: stap 3, afbeelding 1 van 2 KitchenAid KSM150PSER Power Cord Replacement: stap 3, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Using a Phillips #2 screwdriver, remove the 12mm screw holding the grounding wire in place by rotating it counterclockwise.
    • Using pliers or tweezers, remove the connectors attached to the white and black wires.
  4. KitchenAid KSM150PSER Power Cord Replacement: stap 4, afbeelding 1 van 2 KitchenAid KSM150PSER Power Cord Replacement: stap 4, afbeelding 2 van 2
    • Using a screwdriver, pull the cord string relief out of the mixer by putting it behind the cord and pulling away from the mixer until it is free.
    • Remove the cord from the mixer body.
Conclusie
Max Prohorov
109 Reputatie
1 Handleiding geschreven
Cal Poly, Team S2-G5, Livingston Winter 2018 Lid van Cal Poly, Team S2-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S2G5
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 46
Altijd: 4,116
